Ive trying downloading it like about four or 7 times all i know is it still didnt work no matter what i tried doing it just kept saying something on my screen and i just pressed okay
SOURCE: P4S800-MX Bios update
It could be that you have disabled BIOS flashing. Go to BIOS and look for the option and enable it
SOURCE: downloading programs on to asus ee pc
That is because on your computer there is no application associated with the downloaded file.
for example if you download a compressed file (.rar) you will need an unzip software (winrar) to open the file.
If you download a word file (.doc) you will need microsoft word installed.
Find out what kind of file you are downloading, then locate and install the right application to open the file.
SOURCE: flashplayer download
i had the same problem. found it has something to do with windows IE sp3 update. Microsoft couldn't walk us through it after 4 hours. problem solved by downloading Monzilla Firefox browser.
runs MUCH faster than IE ever did!!!!!!!!!!!
SOURCE: lost the software cd for my asus wireless adaptor
Hello Greg,
Check to make sure the device drivers are installed properly, and the device is functioning correctly, and enabled by doing the following:
1. Start
2. Right Click on "My Computer"
3. Select Manage
4. in the left column of the new window that appears, select "Device Manager"
If you don't see any yellow caution signs or red "x" then your device should be ok.
Make sure your wireless radio is also turned on.
What model is the laptop?
What model is the wifi adapter?
Are both from Asus?
SOURCE: I can not download aol or yahoo messenger to my computer.
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
Hi lisa animated brown, I want to help you with your question, but you should read that "something" on the screen. It may not just be a license confirmation but contain actual info of why it is not working ;-)
