I have a singer quantum stylist 9960, when I turn on the machine the screen is showing the winding bobbin picture and not sure how to reset i. When I press the pedal all I hear is a noise. New at this
I just got this machine, it was a gift. Never used it before now
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
Classic burr on the hook problem would be my first guess. If the thread remains on the hook when it makes the next revolution all sorts of ugly things happen such as you described. I made a video that might help.
Oil it! Put a drop of oil on everything hat moves every eight hours of operation," except plastic gears etc". Use only Singer oil on Singer machines. Plastic gears require a grease made from plant.. "Do not use petroleum based oils or grease on your machine,it will dissolve the plastic gears etc". used in your machine..
I'm looking for a solution to why the thread cutter isn't working. It just pulls the thread into a knot and jams the bobbin case. I was hoping for an answer here but the answer had nothing to do with the question!
