Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr Makr Logo
A
Anonymous Posted on Feb 14, 2015
ER3 error code on amtrol hot water tank
I ran out of home heating oil and the tank was left on for several hours.(normALLY SET AT 125 DEGREES). i just got heating oil delivered and the furnace is running but an error code (ER3) shows on the water tank display. how can i correct this problem and set the temp back to 125 degrees?
Brent Michalski
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 40 Answers
  • Posted on May 29, 2017
Brent Michalski
Expert
Level 2:
New Friend:
Greenhorn:
Answers
40
Questions
0
Helped
46325
Points
108
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
  • Brent Michalski
    Brent Michalski May 29, 2017
    It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand.
    CAUSES
    -bad sensors
    -no hot water from boiler
    -bad thermal transfer
    -low delta T across water heater
3 Related Answers
freetek
Steve Allison
  • 5569 Answers
  • Posted on Feb 26, 2009
SOURCE: not enough hot water. I have an Amtrol Extrol coil water heater
Since you mentioned 'both temperatures' it seems your unit is like most all of them, a lower and upper coil.
If your hot water supply runs out quickly, this normally means that the lower coil has failed. Since heat rises, the upper coil will never supply a tankful of hot water, just hot to start, and then as the flow continues, it doesn't have time to do more than warm the water flowing into the tank.
Every home should now own a simple digital multimeter; they cost less than $20 US everywhere and one can find them in auto parts stores, electronic supply companies and tool companies.
If you have a Harbor Freight tool store in your area, you can get them for under $10 US any time and sometimes even less:
Digital meter
You need to be absolutely certain that the voltage to the water heater is shut down. Before you measure anything else, set the meter to its highest AC setting and check across the coils and then from either contact to the metal housing. If it is dead everywhere, then set the meter to the lowest Ohms scale (normally 200). The resistance of the coil should be nearly the same reading as when you simply short the meter's probe tips together. If it measures 'OL' then the coil is open and must be replaced.
Anonymous
  • Posted on Dec 28, 2010
SOURCE: ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Gene Haynes
  • 5391 Answers
  • Posted on Mar 19, 2013
SOURCE: hot water not lasting long enough
Check for crossover to eliminate plumbing problems:
http://waterheatertimer.org/Crossover.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
3answers
Boilermate er3
is it an electric or gas or oil fired. Er3 means it is not getting up to temperature within the required time. Electrical - element bad. for oil or gas, no ignition or fuel supply.
What does an error code ER3 tell me?
CAUSES
-bad sensors
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
I'm getting an er3 reading on my water heater tank , what does that mean
CAUSES
-bad sensors
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
I have a ER3 message. How can I fix this
CAUSES
-bad sensors
8helpful
ER3 no hot water
Need new aquastat.
1helpful
2answers
No hot water from the Amtrol Boiler Mate model wh7p
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Top Amtrol Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
