Hedge trimmer will not start checked muffler and removed to see if there was any score marks on the piston replaced all gaskets heat dam was cracked so i replaced still no go replaced spark plug cleaned carby
SOURCE: reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
SOURCE: Poulan Gas Hedge Trimmer GHT220 shuts off after 10 min.
your ing. coil is breaking down as it heats up needs to be replaced
SOURCE: Have zrry30550 Ryobi Hedge Trimmer (reman.) I
Hello. Get a can of starter fluid and a helper. Spray some into the air cleaner and start it up. Have your helper continue to spray a little starter fluid to keep it running for a minute or so. This will clear whatever blockage you have. Once it sounds like it is running well stop adding starter fluid and see. Joe
SOURCE: Ryobi 700r string trimmer issue. Unit will not
Hi have you checked the carb for dirt?,does the primer bulb work?does the plug get wet?also have you tried to change diaphram/kit there is a company on ebay called smallplantsalesuk where you can get the parts,rgds
