By 'door valve' it is assumed you are referring to the ice and/or water dispenser operation. If so, it is located behind the panel covering the door opening where the fill mechanism is located. This is typically held in place by clips, molded into the panel and the valve or dispenser opening is a solenoid. You would greatly benefit through the assitance of an appliance repairman.
Hello - Typically when water is coming out from under the refrigerator there could possibly be a loose connection from the house water supply line to the water valve or a cracked drain pan (located underneath the refrigerator). Try confirming that the valve is tightened. If the connection is still leaking, turn off the water supply valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. There could also be a loose water connection to the door. This connection is located on the bottom left of the freezer door.
