Desa International White Wireless Plug In Door Chime Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
I have a normal door bell which for some time now refuses to ring from the metal bell on the wall inside the hall. I have replaced batteries and onto my third (outside) door button push bell now but cannot find what the problem is as all it does is just make a slight buzz when the bell is pushed which cannot be heard. It operates by the old fashioned metal bell on the wall inside the hall where the ringer tings inside the outer metal casing which makes the ringing noise. Having constantly changed batteries and bell pushes on the door I thought it may be something to do with the bell ringer itself as I was getting this soft buzz when the button was pushed which meant there was contact there somewhere. I tightened up the screw on the outside of the metal bell in the hall and for once (and once only) it actually rang as a bell should but we are now back to the soft buzz again when the outside door bell is pushed. What could be the problem here? Surely there is not much that can be at fault with the actual metal bell inside the house but it seems that is where the problem must lay having rung once. Does it matter whether the metal casing is hanging losely over the ringer or tightend up tight with the screw for it to make contact with the metal to ring properly or is it a whole different problem?
John Morganti
Level 3:
  • Master 864 Answers
  • Posted on Jul 08, 2009
John Morganti
Master
Level 3:
Answers
864
Questions
Helped
373631
Points
2813
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Julian Pearson
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Jan 04, 2013
Julian Pearson
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
10962
Points
84
Easy solution. The round bell bit is secured off centre so that volume can be adjusted... Turn the round metal bell 1/4 turn anticlockwise and press the bell button... Then another 1/4 turn until the solo pod hits the metal.... The TIGHTEN the central screw to stop it turning back to silent.
  • Fred Shaub
    Fred Shaub Sep 07, 2015
    Many thanks. It worked a treat.
1helpful
1helpful
I have a blyss door bell with additional plug-in bell. The bell works fine but an orange light flashes on the plug-in bell.
Try this:
Reset the Unit
- remove all the batteries from the bell
- ensure the battery in the doorbell unit is working and remove the back cover
- replace the batteries in the bell unit
- within 30 seconds of the bell unit sounding the bell, press the melody changer button on the back of the door bell unit once
Pair the Unit
- wait at least a minute after reset
- within 30 seconds of the bell unit sounding the bell, press the door bell button
Rind doorbell doesn't stop ringing
it is possible that the doorbell button is sticking down and keeping contact - so the doorbell keeps chiming.
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
1helpful
3answers
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
My 3.2 IR 166173 BELL remote wont work on my bell reciver
Ensure that the TV is turned on. Turn the Bell receiver on manually (at the receiver). Remove the batteries from the remote. Press the "Power" button on the remote until no buttons on the remote light up (a half-dozen times). The satellite service (your Bell service) will likely have turned itself off in the process. Replace the batteries in the remote. The remote should now work as "normal".
LiftMaster garage door opener won't open. When push button (from either remote or "door-bell" style button on wall), unit makes a slight humming sound for a couple of seconds, then nothing...?
Check the door springs and also the drive gear. The gear is a white nylon gear just in front of the motor unit. It will be pretty obvious if it is going bad. The door spring may be broken.
Does a soft sounding warning bell indicate a problem somewhere? Sometimes the bell is normal other times the bell is soft.(quiet) This is for a 2006 Chevrolet Impala.
Usually makes sound when your seat belt isn't on or clicked together all the way. Also could be a sound letting you know your door isn't closed all the way.
I have two door chimes with the same frequemcy, but different codes. I need to place the chimes in different rooms as I am hard of hearing. How do I match both codes so that they ring at the same time when...
You need to change the pin configuration in both the remote buttons to match each other, (as well as the bell unit) just make sure they match on both bell units. Also, since one works just use that configuration and change the button pin configuration that does not work to the button that does on the other button unit.
2answers
Top Desa International Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
