Hello, I have a Huyndai Accent 2006.
1 month ago, my low beams started to act strange : sometimes they were working, sometimes they were not.
Then now, my low beam and high beam quit working. Flashing my hight beam works tho.
its been 4 days now that my lowhigh beam do not work.
The light bulbs are fine, I put new ones. I had a friend tested the voltage of the light to make sure they were fine and everything is ok.
My *blinkers* are working fine, my parking light too, break light ect too, only the low\high beam.
I've been told that I might have to change my *switch*, but I just want some experts opinion before getting into that. Thank you !
Check for headlight relay and fuse. Some cars have separate circuits for head light flasher and normal high/low beam. From your description, I would suspect a bad connection to/from relay or relay itself.
Hi i have a hyundai accent 1998 my full beam on head light seems to have quit working does anyone have any advice on this problem all other light working fine
Yes i would change the switch.It as all the symtoms of the switch being faulty.
