At the moment i have just changed the fuse
LUBE the deck belt with grease or WD-40 o any silicone lube.
try to loose the belt deck in the way that when you lift with you finger will be 2" max. See the drive belt , must have a deflection with your finger 1/4" aprox. Of course time to maintenance motor: lube the bearing or replace, and the carbon brush. Lube the deck bel 1time every week.
However you must test the voltage to the terminal to the motor from 0-180 Vdc, if NOT replace the Motor control Board
Do not use a grease on domestic Nordictrack I sell treadmills . Silicone based products are the best to use . The spray doesn't last long , the silicone based oil lasts longer .I sell the kits with oil recommended by the company who own the brand . If you use the grease you will VOID your warranty. TRB is a Authorized repairer for this brand in Australia
