52 inch projector tv will turn on then and work for a while then go black but there is still sound. when u turn it on with the remote the power button flashes all crazy sometimes.
Letting it col down. left it unpluged for about two months
First is you removed power by unplugging the surge protector---this may have confused the micro in the set.
Unplug the set itself (with it turned off) for a while and plug it back to see--sounds like this is your problem to me. Usually in this case only the on/off button on the set works.
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
It sounds like the CP150 and or the CP114/120 capacitors need to be replaced, they cost around 3 dollars each and can be found at Radio shack or you can order them from http://servicemanuals.vstore.ca/ and they will send instructions with them.
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
