To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
PRINTER TRY TO PICKUP THE PAPER,BUT PRINTER CAN'T.THE CAUSE OF THIS ERROOR IS FAULTY PICKUP ROLLER & SEPRETION PAD.SOME TIMES PAPER TRAY CAN NOT BE OPEN WHEN WE PUSH IN,IN THIS CASE PRINTER SHOWS PAPER JAM
1. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
open all door in your printer , front and back. , look for paper stuck inside and remove it. Sometimes small pieces of paper are difficult to be found. If it is a Laser printer, you will also need to remove the toner and paper try and look for jammed papert underneat. Once you done, restart the machine. If you still have paper jam error try unplugging printer from power outlet for 5 minutes then restart. If you still get error, then either there is paper inside or your printer may be faulty.
