Refrigerators Logo
R
Ray Thorburn Posted on Feb 05, 2015
My 2004 Kenmore leaks water at the water filter housing. I put a new filter in but when I wish to get water it overflows at thde top.
Replaced filter. Thought the o ring may be bad so I used some plumbers putty at threads to the interior filter. Model #253.56522400
A
Anonymous
Fist issue, plumbers putty should not be used on any water connection for potable (drinking) water, use Teflon tale if you need to. If the leak is at the housing most likely the housing is bad, replace it.
1helpful
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
What causes leak between filter and filter housing on kenmore elite model 40141003010.
Hello Emile;
My name is Peter. I am a retired field service refrigeration technician.
I assume your changed the below component:
25693704-zbtre13rzitqz5mqvrpod1im-1-0.jpg At the ends of the plastic tubing are plastic push pull connectors. If the tubing is not properly seated and locked into the connector you will have a leak.
You may also have a crack in the connecting tubing from the water tank.
When you use your water dispenser, the water dispenser solenoid valve allows 65 PSI water pressure into the plastic tubing line, where if you have a bad connector or a crack in the line will cause a leak.
The is a plastic cap on the top of the above component.
1.) Put your fingers behind the above component where the tubing goes into the plastic mounting head. More often than not you can get bad parts
2.) Have someone push the water dispenser lever. Observe if water is running down the plastic tubing or if your fingers are getting wet.
Kenmore refrigerator water filter bypass
That is a tough one. You can remove the water hoses from the housing but it won't be easy. Unless the housing itself is broken I don't think I would recommend bypassing it. Now if you really do want to go this route, here's how I would do it.
1) Turn off the supply
2) Carefully remove both lines from housing
3) Using the proper fittings, splice enough line so that you can position the new inline filter at the rear of the unit.
4) Attach the proper quick connect fittings to the new lines.
5) Install the new inline filter .(You may wish to secure the new assembly to the back of the unit)
6) Turn supply back on and check for leaks
As far as which filter, there are many to choose from. I would just get an inexpensive, inline filter made for ice makers. just be sure you get the correct quick connect ends for your new installation.
You can also purchase a complete kit which comes with mounting hardware, a filter and everything you need. This won't be inline though. It will be a separate housing which you will just mount remotely.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
1helpful
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
2answers
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
How do i replace the water thmostat 99 6 cylider
WELL YOU NEED TO DRAIN COOLANT LEVEL BELOW THERMOSTAT LEVEL.YOU HAVE TO DISCONNECT MAF SENSOR LOOSEN AIRDUCT 2 LARGE CLAMPS LOOSEN REMOVE 4 SCREWS TO AIR FILTER COVER LIFT UP REMOVE COVER. THEN REMOVE AIR FILTER AND HOUSING, FIRST DISCONNECT MAF SENSOR.YOU HAVE TO DISCONNECT THROTTLE CABLE AND SHIFT CABLE.YOU HAVE TO DISCONNECT REMOVE THROTTLE BODY COOLANT HOSES DISCONNECT IDLE SPEED CONTROL VALVE CONNECTOR AND DISCONNECT TPS SENSOR CONNECTOR. THEN REMOVE THROTTLE BODY ASSEMBLY. YOU NEED TO BUY NEW THROTTLE BODY COOLANT HOSES AND NEW THROTTLE BODY GASKET FOLLOW TOP COOLANT HOSE TO ENGINE BLOCK.NOW YOU SEE CAN AND REMOVE THE THERMOSTAT HOUSING REPLACE THE THERMOSTAT.BESURE TO HAVE EXTRA COOLANT ON HAND.BLEED COOLANT SYSTEM WHEN DONE.TO BLEED COOLANT SYSTEM REMOVE RADIATOR CAP ON OVERFLOW JUG.THEN OPEN BLEED SCREW ON THE WATER PUMP BYPASS HOSE PIPE JUST A LITTLE.POUR COOLANT IN THE OVERFLOW JUG UNTIL LEVEL STOP DROPPING.STOP AT COLD MARK ON JUG.CLOSE BLEEDER SCREW ON WATER PUMP BYPASS HOSE PIPE.CRANK VECHICLE CHECK FOR LEAKS. START UP ENGINE LET IDLE FEW MINUTES THEN CHECK COOLANT LEVEL ADD MORE UNTIL UNTIL LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON OVERFLOW RESERVOIR. LET ENGINE IDLE WATCH COOLANT TEMPERATURE GAUGE.WHEN GAUGE START CLIMBING. TURN OFF ENGINE WAIT FEW MINUTES TAKE A LARGE RAG OPEN RADIATOR JUST A LITTLE YOU HEAR HISS NOISE.WHEN PRESSURE STABILIZE DONT GET SCALDED BECAREFUL.OPEN CAP LITTLE MORE.IF COOLANT PRESSURE STILL BOILS OUT WAIT 20 MINUTES ADD MORE COOLANT TO RADIATOR OVER FLOW WHEN COOLANT LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON START VECHICLE UP LET IDLE UNTIL THERMOSTAT OPEN. THEN FEEL TOP RADIATOR HOSE FEELS HOT THERMOSTAT OPEN WATCH TEMPERATURE GAUGE.IF GAUGE TEMP START CLIMBING TURN OFF ENGINE WAIT A WHILE.CHECK AND ADD MORE COOLANT.WHEN THE ENGINE CAN IDLE TEMP GAUGE STOP CLIMBING YOU HAVE BLEED COOLANT SYSTEM.KEEP CHECK ON COOLANT LEVEL.
9helpful
2answers
I replaced my Whirlpool Ultraease Undersink Filtration filter model WHEEDF and th Filter 1 of the pair of filters leaks. I have applied teflon tape to the threaded pin of the mounting unit and the leaks...
I would shut water off and relieve pressure. Remove filter houseing and inspect rubber gasket on bath sides, clean it off and clean inside of cap where gasket sets and on top of housing. Make sure there are no rough spot on either surface. If there are you can smooth them out by using fine grit sandpaper,no coarser then 120 grit. Wipe all surfaces clean and apply 5-6 wraps of teflon tape on threads on filter housing. Before you put gasket back in place you can put a light coating of petroleum jelly,vaseiline or similar,on both sides of gasket. wipe off excess. Reinstall filter and housing. tighten securely. Turn water back on and check for leaks. If it still leaks you can tighten a little more. If it still leaks I would replace gasket. Hope this helps.Thanks
Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
Water filter housing leak
Leak just stopped on its own. No idea why.
Kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
