I have tried putting the RF to on, on the sky box and it states channel 68 but when I go to TV in the other room the channel 68 is a DTV channel and there is no terrestrial channel on my LG 50PH660V 50-inch TV and I am unable to connect the sky from my sky set top box in my sitting room to TV in bedroom through TV link even though the magic eye on the TV link lights up I can not get the sky on TV in a different room
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
SOURCE: can you show me how to connect up the scart and
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
