Given the amount of electronic's ( computers ) on your vehicle ,it could be a lot of thing's . Hooking up a factory or professional grade scan tool that can communicate with all the control modules on the vehicle should be the first step in the diagnostic problem . Checking for DTC'S - diagnostic trouble codes , communication between module errors etc.....
Your best bet , take it to a qualified repair shop that has the proper diagnostic equipment to check it out .
The power door lock system consists of the following components:
• Body control module (BCM)
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• Door lock system fuse into the BCM (BCM D 25A fuse)
BCM Functions
The body control module (BCM) is capable of accomplishing multiple body control functions. Components directly connected to the BCM are controlled by the BCM outputs. The BCM can control its outputs based on input information it obtains from sensors and switches that are directly connected to the BCM, or by receiving information from other vehicle systems connected to the class 2 serial data link. The BCM evaluates this information and controls certain body systems by commanding an output on or off.
The BCM is also capable of commanding other vehicle systems to control functions that are not directly wired to and/or controlled by the BCM. The BCM accomplishes this task by sending specific messages on the class 2 serial data link. The vehicle system capable of performing such function will respond to the BCM message.
The BCM controls/monitors the following functions:
• Audible warnings
• Indicators control
• Interior lighting
• Exterior lighting
• Power/automatic door locks
• Keyless entry
• Content theft deterrent
• Personalization
• Serial Power Modes
• Electrical Power Management
Buick Class 2 Operation Diagnosis 1998
