SOURCE: 2006 sportsman x2 500 ho
have an 06 polaris sportsman 500 x2, when i turn the key nothing happens. battery is good and charged, i have another quad, same exact one, and i have swapped out every part i could to find out what is wrong with it, still doesnt work.
SOURCE: 2005 Polaris 700 sportsman 4x4 gets warm, looses power?
My 2005 700 efi is doing the same thing. So far I have found that the engine and exhaust get so hot that the fuel starts to boil and causes the fuel pump to vapor lock. I taped up the tank with some reflective tape/insulator stuff and now I'm trying to figure out why its running so hot.(The exhaust manifold glows red hot) I've cleaned the radiator and flushed the system. I just need to check the water pump and thermostat. Any other suggestions?
SOURCE: 2004 polaris predator 500 3 new batterys dying can't charge them
I hope you got this problem fixed, just happened to my predator, it was indeed the voltage regulator. I picked up a service manual that includes part numbers and installation procedures from www.promanuals.net for 15 bucks.
SOURCE: overheating polaris sportsman 700
you probly need a new heat sensor, its located on the bottom right of your rad, i had the same problem with my 700 the fan only worked when it was already over heating, i cut the wires flush at the sensor drilled a hole above the key switch and mounted a toggle switch, no more over heating,
SOURCE: 2004 polaris sportsman 700 main Fuse?
Can i get a wiring diagram for a 2004 polaris sportsman 500 H.O. i get no powere anywhere. [email protected]
