SOURCE: front panel removal
make and model number would help, post these details and i may be able to help
SOURCE: Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
SOURCE: whirlpool washer control locked
hold down the End of Cycle Signal for 3 seconds that will release the control lock function
SOURCE: No power to Whirlpool duet front loading washer
sorry no reset on that model but check the outlet
SOURCE: push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
