OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked. - Inspect the Drainage hose at the back for kinks. - If any, straighten the hose - Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. It has small holes that **** water away after the main wash, and while rinsing. Foodstuff may be blocking these holes, also remember to clean the filter after every wash.
Kind Regards :-)
If you found this solution helpful, please rate it.
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
"OE"
Drain error. Cause: not fully drained within 10 minutes
Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludgeOR
"OE" - Water overflow error
Water supply does not stop after sensing an overflow condition.
Turn off household water supply to washer and unplug power cord. · Check wiring harness · Check water inlet valve · Check pressure sensor switch · Check circuit board
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Hi there, The most common cause of an OE error code on a modern LG dishwasher is: 1. Blocked drain hose 2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Hi, The most common cause of an OE error code on a modern LG dishwasher is: 1. Blocked drain hose 2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3. Failing drain motor. else you need to REPLACE THE PCB POWER CONTROL BOARD Good Luck!!!
Hi there, The most common cause of an OE error code on a modern LG dishwasher is: 1. Blocked drain hose 2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3. Failing drain motor. else you need to REPLACE THE PCB POWER CONTROL BOARD
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
