I bought an old bobcat but it doesn't have a manual. i just want to check, oil, water, that sort of thing before i give it a run.
Check that you can open the rear of the unit, pins on one side and hinges on the other . This reveals the radiator and allows certain access to the motor.
Testimonial: "Turns out this model is air cooled so requires zero water. That makes it a bit easier. Thanks anyway."
Yes... I've had a m600 for about a year. I love it when it is running, but it seems to overheat due to the air cooled engine... will only run for about an hour before it overheats.
the fins around the head and cylinder have to be kept clean for the motor not to overheat. If the fan for the air flow is belt driven then it may be slipping and not delivering all the air required. It is essential that all the air flow shields are installed
