Read this post on how to adjust bow. https://goneoutdoors.com/adjust-length-jennings-compound-bow-7184260.html
In order to find out the exact draw length, hold a tape measure in your bow hand and then pull the tape measure as you would a bow string to the corner of your mouth.
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
A Reflex bow
is a unique bow that has curved arms that turn away from the archer. The curves
put the materials of the bow under greater pressure, allowing a fairly short
bow to have a high draw weight and a long draw length. I personally own a
Reflex bow of my own an had lots of other bows and for me it's the most
powerful bow I've ever used, so you defiantly try this bow out.
