Reseting the pump
I think! then.... is because you must reset it all. like disconnect,
press the reset button, hold it or anything like that so to put it in
the basic form. i think is because is programmed, not configured
right. you must have press too many buttons and the software
program acts this way. try resetting it all to "default". good luck!
- Power up the router, and wait for it to complete booting up, typically about one minute.
- Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
- Wait for the router to reboot.
- Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
- Unplug the router's power.
- Press and hold the Reset button. While the button is held down, reconnect router's power.
- Continue to hold the reset button for 20 seconds after reconnecting the power.
When operating, errors happen. Turn off the device.
(To turn off, press and hold the power button on the front
of the device for 10 seconds.)
After turning off, press the Open button and remove the
disc from the device
If needed reset the device to its factory settings after the disc is ejected. To reset it to factory settings:
Press the [UP] and [DOWN] buttons on
your DVD recorder simultaneously
when the power is on. All settings
including the password will revert to
the factory settings. Do not use this
unless absolutely necessary.
(Note that this function is possible only
when no disc is inserted.)
ok.
