Reprogram the DVD on TV in the component mode but plays in black and white only my direct TV box has has a HDMI cable to try hook up DVD to side of TV yellow to video and red and white to audio please help me thank you
SOURCE: dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
SOURCE: DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
SOURCE: how do i hook dvd player to tv..i know its probably simple
The yellow and white cables hook into your tv inputs
SOURCE: Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
SOURCE: Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Testimonial: "Thanks for the help...I did have the tv on the wrong video channel. It works now!"
