magicJack New & Improved 2012 Plus Free 1yr Subscription Magic Jack Logo
M
Maria Burgos Posted on Jan 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I tried to register a new MJack plus, last night but it was imposible. Then I went to the bed, what a surprise this morning, i found that the MJ was working with an ares code from Florida, I want a T
How do I change my Mjack # from Florida area code to Toronto. from 239 to 416
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,226 Answers
  • Posted on Jan 22, 2015
James Miller
Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447472
Points
2985
In your acc you can do this ok
We are on our second 22" queen airbed in 4 months the first started deflating after about 3 months the 2d we bought last night and it lost air after 2 hours. Aired it up went to bed low this morning?
change to a brand that doesn't leak
euro bed is such a bed is 350 mm high will carry mini minor cars , tractors and 500 lb weights over 24 hours with out deflating
get the best and forget the rest is the manufacturers motto
found on line
google--- eurobeds
I HAVE THE NEW MAGIC JACK PLUS. WHEN I PLUG IT IN I GET A MESSAGE TO WAIT TO REGISTER. I HAVE WAITED OVER 1 HOUR. HOW MAY I REGISTER?
Waiting, 'time" will not resolve this issue. Its a common problem where the MJ isn't talking to their servers. i would check your internet connection to the device as a first step. Change ethernet cable, even if the one you're using has worked before. Weird things happen to cables, some unseen....its always easier to assume a cable is bad and replace it or if you know how, test it within your own network.
The other solution would be to check on what ports are open for the MJ through your router. Offhand I cannot remember what it requires, but it could be that the router is blocking the signal, so the MJ cannot find the servers it needs.
Other than that, there a ton of tech support written on the MJ and the MJ Plus. I have both and had problems with the first two MJ's and didn't register my MJ Plus because I gave up on a home line.
I know that's not a simple answer, but I hope it points you in the right direction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chad_65e28e99f5372e81
My coffee pot died during the night
It had nothing to do with the coffee pot. I blew a breaker!
How do I unlock my lg electric oven that is on ''oven lockout''
LG had a recall awhile back because the control panel touch control switch was right over the oven vent (on the right side) and use of the oven made it randomly cycle lock/unlock+ ding all night long for weeks.
Throwing the breaker off for the night was the only recourse, besides having LG replace the control panel.
I found that it would eventually fix itself (!), but come back at some point here and there, and then disappear weeks later.
1helpful
Won't come on
Replace Ic 901 (STR-M6511) and check for bad capacitors in the power supply.
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Top magicJack Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
