Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
What does a run capacitor. On my heater look like
    New Friend:
  • 26 Answers
Below is a picture of the motor, if you look at the wires you will see a round canister like object with 2 wires going to it, that would be the capacitor.
What does a run capacitor. On my heater look like - run-capacitor-heater-look-like-2pqc5t5nr5th3au2lltr4oyu-4-0.jpg
Posted on Jan 21, 2015
Anonymous
SOURCE:
Why would a torpedo heater fan turn backwards? every time I start my all pro 115,000 heater the fan starts to spin counterclockwise and the heater wont ignite. But when manually spin the fan blade clo
If the fan has a 'run' capacitor, in rare cases, a faulty capacitor will cause a single phase motor to start in reverse. In most cases a faulty capacitor will cause the motor to only hummmm and not start or start slowly running the right direction then overheat and shut off.
See if there is a capacitor, change it first. If that doesn't fix it it sounds like its time for a new motor.
Nov 18, 2014 | Heating & Cooling
Tip
If you're troubleshooting HVAC electrical problems 230 volt single phase ac The...
The Common wire or circuit on an A/C or heat pump never has a run capacitor in that line.
The Run wire always has the run capacitor in that line or circuit.
115 volt ac
The Run or Hot wire has the run capacitor and the neutral wire does not.
So if you are tracing wires out in a circuit, if there's a run capacitor, it's the Run wire or Run circuit.
The Start wire always goes to the opposite side of the run capacitor than the Run wire and it is the only wire on that side of the capacitor.
The Run wire goes to the run capacitor, then goes to contactor, compressor, start capacitor or fan, so there's usually two wires on the Run side of the capacitor.
on Jan 07, 2010 | Heating & Cooling
Motor spins backwards
Motor should have the rating on the motor TAG if it is a run capacitor
Dec 17, 2013 | Reddy HEATER R115 115,000-BTU PORTABLE...
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
Air compressor on Heil air conditioner is humming but not kicking in
Capacitor Failure Symptoms are sometime harder to identify without the right tools and expertise. Capacitors can be found in several different sizes and shapes. There may be one or multiple capacitors included in your ac with regards to the design. While the most popular capacitors are the types found on circuit boards, the ones most associated with air conditioning will be the bigger capacitors that assist start and run your motors. There are several motors present in an conditioner and heater systems:
  1. Compressor Motor Run Capacitor: Here is the most popular capacitor that fails. Most of the time these are duel capacitors, which means that there are 2 capacitors built into one. A duel capacitor will have three terminals on the top where a single capacitor will simply have two terminals on top.
  2. Outside Fan Motor Run Capacitor: That is the smaller capacitor found with or part of the Compressor Motor Capacitor. It helps start and run the outside fan that blows air through the outside coils.
  3. Indoor Blower Motor Run Capacitor: Similar to the outdoor fan motor capacitor, it is a small, single (two terminals) capacitor that will help start and run the indoor blower motor.
  4. Start Capacitor: Some models include an auxiliary start capacitor that helps jump start the motors. Most are found on the compressor. These are less common.
You may need to get that checked out.
Air Conditioning
Oct 16, 2012 | Heating & Cooling
My hot water tank won't start, i can hear humming sound from the blower, but blower doesn't run, ant it does no heat.
If the blower will not run, then the unit will not fire up due to a safety hazard. If it is a capacitor start motor, then you may have to replace the capacitor, otherwise you will have to install a new blower motor. Hope this helps
Apr 03, 2010 | Fasco Bradford White Hot Water Heater...
Heater blower switch only works in postions 3 and 4
When this happends, it usely is caused by a bad blower motor resister. I can't tell you if it is a seperate unit or if its built into the blower motor . If its a seperate unit it should be located close to the blower on the heater box, if its in the motor you will have to replace the motor.
Sep 16, 2009 | 2004 Ford F150
R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
Feb 15, 2009 | Desa International ReddyHeater® R115DT...
Motor capacitor seems to be burnt, motor does not run
I would replace that and the high heat limit control, it deffinitly got to hot.
Dec 22, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
393 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
