Refrigerators Logo
T
Tracy Anderson Posted on Jan 20, 2015
How does the pur water filter work? Is it powered by a battery or is something else involved? My light will not light green or red after changing the filter sometime ago. Does it come apart?
Ilia B
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on Jan 20, 2015
Ilia B
Contributor
Level 1:
New Friend:
Answers
37
Questions
0
Helped
9793
Points
67
It runs by water preasure. filter does not come a part. try to unplug the fridge for few minutes and plug back in. if that does not help see instruction to reset yje unit
Kitchen faucet purwaterfilter
the light has a battery that 's not replaceable. it wears out and then the light doesn't work any more. you just have to guess when it's time to replace the cartridge. (I got a new filter that i like the color better, after i used the old one for a while after the light ceased working). might be under warranty.
21helpful
3answers
PUR Faucet Mount Water Filter indicator light does not work
Take it loose from the faucet and flip the lever down on the filter in the on position. Take the cap off and remove the filter. Blow hard through it. You should hear a whirling noise of a gear, like a windmill. If not, I use a water dental pic to pulsate into it and clean it out. This is what makes the light work and when flow goes down, the light changes color. It's all mechanical. No battery. Just free up the gear so it turns freely to work the light. If standing in front of a mirror, you can actually see the light come on. PUR doesn't tell you this because they want you to purchase another one.
Change filter light
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
7helpful
Red led light on constantly
electronic circuit needs replacement
Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
5helpful
Water filter
electronic circuit needs repair
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
