Garden Logo
b
bobby dale marcum Posted on Jan 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What makes a white outdoors lawnmower charge
I got to keep jump starting it
Bill Gonda
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 09, 2015
Bill Gonda
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
770
Points
You may not have a charger on your model. If you battery is three or more years old it may need tobe replaced.
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Feb 07, 2015
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215281
Points
1078
Need to know what engine you have
Heat pump wont come on
Make sure you have power to the outdoor unit. The outdoor unit on a minisplit powers the indoor unit.
Why is Mr Slim MS-SGF24VC outdoor unit working when indoor unit off
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2helpful
My lawnmower has to be jumped every time I use it, I've got a new battery and I still have to jump it? What could be causing my battery to die,
The alternator may not be charging. You can get a volt meter and check it before jump starting, after it is running, and before turning it off. Let me know the results please.
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 • Garden
My honda riding lawnmower will not start. Battery is good, however when I put jumper cables on and jump the lawnmower the engine will turnover and will stay on only 5-10 minutes when jumper cables are...
check your charging system, likely your regulator, i would have to see it to tell you where the regulator is located also clean the magneto contacts
Jun 08, 2010 • Garden
2answers
I have a craftman GT5000 Lawnmower it quit charging were do i look for alternater?
The charging system is under the flywheel, but first check the 2 wires are connected at the side of the motor, they might be black and white at the conector.
3helpful
2answers
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
My huskee model # 28 N707 lawnmower will not keep running.
It sounds like 2 different problems. One is that your battery is shot. It needs to be replaced, and to keep that from happening prematurely, put a smart trickle charger on it over the winter because lead/acid batteries lose 1% of their charge per day, making them virtually discharged in 3 months. This causes damage that they cannot recover from.
The second problem sounds like either that you are not tending to the choke properly or it needs the carburetor thoroughly cleaned because of clogged jets. Before winter storage, be sure that any fuel in the system has been treated with STA-BIL to prevent it from breaking down and forming deposits.
If you have the technical know-how, get a carb rebuild kit (usually about $20) and remove, clean, and reassemble the carb using the new gaskets and parts. If not, bring it in for repair.
Top Garden Experts
Jay Finke
Jay Finke
john h
