I can not find the manual and I need to enter the information for a programme I am installing
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: toshiba satellite pro u400-13r laptop sound drivers
Go to this website: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# and find the download tab. Select your category and find the sound driver to download. Once it's download, install it and restart your computer to take effects.
NOTE: If the driver is incorrect, your PC will be at risk.
SOURCE: ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
SOURCE: I can't instal Windows Xp for my laptop Toshiba Satellite L310
because of that u have sata hdd in your laptop you have install sata driver in your laptop and try to install windows xp or use the windows xp darkl edition to install in your pc
SOURCE: I urgently need a toshiba
Here is the manual. Just download it:
http://safemanuals.com/user-guide-instructions-owner-manual/TOSHIBA/SATELLITE%20PRO%20P300-_E
Here is a guide as to how to disassemble it too, which should also help you:
http://www.laptopka.com/2009/05/10/disassemble-toshiba-satellite-p300-p305-laptop/
