LG 32LD350 32 in. LCD TV Logo
n
nick tomlinson Posted on Jan 17, 2015
This function is not available sign keeps coming on
Fiddled with the energy saving button, but no difference
kevin higgins
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jan 17, 2015
kevin higgins
Contributor
Level 1:
New Friend:
Answers
30
Questions
Helped
18636
Points
95
Sounds like a problem with the remote where a function button on the remote is being pressed for a function which is not on the TV. Could be a fault in the remote or moisture or some other foreign body which has gotten into the remote. Try removing the batteries from the remote or covering the infra red receiver sensor on the TV. Hopefully this will stop it. It may alternatively be some other infra red source which is confusing the TV. The TV generally won't have unavailable functions in its own menu so it's most likely the remote. Hope this helps
  • The Mad Hatter
    The Mad Hatter Apr 24, 2016
    The exterior buttons (chan up/down, vol up/down, menu, input) were somehow on the fritz. I took apart the back cover of the TV, and found that there was a 'circuit board' that was connected to those buttons. I simply disconnected that circuit board from the rest of the TV. Of course, my buttons no longer work, but at least I can control the TV via the remote with no problem.
New Age Electronics
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Jun 30, 2015
New Age Electronics
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
Helped
1315
Points
9
How about you check the IR BOARD for corrosion, usually the main cause of this problem.
1 Related Answer
Anonymous
  • 505 Answers
  • Posted on Jun 03, 2010
SOURCE: How do i turn on TV after pressing energy saving button TV not on
Some of these have a switch on the front you have to click to send power to the circuits. Make sure this is clicked in and then try to turn it back on. The switch may be kind of hidden underneath. If that doesn't help, try unplugging the set for 1 minute, plug it in and wait 1 minute, then try to turn it on. Let me know if this does not solve your issue, we can diagnose further.
How to keep Energy saving screen from coming on
Energy saving screens dim to save energy when no key is pressed after a certain time. You probably have an option to set or reset how long this will take to occur. Look in your settings and find an energy management or similarly titled category. It is a good idea to explore any new device. Don't change anything until you have a grasp of what is available, then change ONLY one item. If you check out how it performs and you like or dislike it, you can go back and change it back. It is called a learning curve and that is how you should proceed.
tip
Make Your Pool Green!
Energy Efficiency <i>Make Your Pool Green!</i><br /> Pool owners LOVE green pools. Crazy statement if the "green" you're thinking about is unclean, algae-filled water. But when "green" means eco-friendly, a "green" pool is something homeowners should aspire to have in their yards.<br /> Energy Efficiency - Why? Why should I build or upgrade to an energy efficient pool?<br /> <ul> <li><b>1) Reduce Costs:</b> You'll save money. Energy-efficient pool appliances always pay for themselves in reduced electric bills, and then continue to save money for years to come. By choosing pool equipment such a variable speed pump or pool cover, and by establishing good habits like lowering the pool heater when not in use and proper preventative maintenance, costs to a pool owner can be greatly decreased.</li><br /> <li><b>2) Cuts down on energy waste and saves water:</b> Almost all of a pool's heat loss-about 95 percent-occurs at the surface, mostly through evaporation to the air and radiation to the sky. By using a pool cover to prevent heat and water loss, the amount of chemical water treatment will also be reduced. A multispeed or energy efficient pool pump can also significantly reduce the power consumption of a swimming pool by over 65%.</li><br /> <li><b>3) Tax incentives and rebates:</b> Did you know that some states offer tax incentives and rebates for homeowners that purchase energy efficient pool appliances? Check to see what incentives or rebates are available in your state..</li><br /></ul> Energy Efficiency - How? With a combination of pool products and good preventative maintenance habits, you can improve the heating and energy efficiency of your swimming pool.<br /> <ul> <li><i>Pump Efficiency-</i> You can save energy and maintain a comfortable swimming pool temperature by using a smaller, higher efficiency pump and by operating it less. On average, an energy efficient pump will use 30-45% less energy than that of a standard pump. The difference over a season can be immense. Pumps now come in two-speed, four-speed, and variable-speed models, so you can turn the speed down for regular daily use saving a lot of energy, and use higher settings for more thorough, less frequent cleanings. New energy-efficient pumps also move the water more efficiently for further savings. Since pumps circulate the water to keep it clean, the better they work, the less a filter has to work. <ul> <li>The <a href="http://www.pentairpool.com/pool-pro/products/pumps-inground-intelliflo-vs-3050-vs-svrs-variable-speed-pumps-76.htm">Pentair IntelliFlo&reg;</a> High Performance Pump is the world's smartest swimming pool pump. Its onboard computer and intelligent software automatically calculate and program the minimum flow requirements for every pool task - filtering, heating, cleaning, spa jets, water features and more - to optimize performance and minimize energy use. As functions/tasks change, IntelliFlo&reg; self-adjusts to maintain optimal flow rates for further energy savings.</li><br /> <li>With the <a href="http://www.haywardcanada.com/inground/products/pumps/EcoStar.cfm">Hayward EcoStar</a> family of pumps, money flows back into your pocket. EcoStar is the industry's most energy efficient variable speed pump, thanks to a super-efficient permanent magnet, totally enclosed fan cooled (TEFC) motor and industry leading hydraulic design. Tests prove that EcoStar can save you up to 90% on energy costs compared to ordinary single speed pumps. EcoStar matches pump flow to a pool's needs, versus running at full power 100% of the time. It's fully programmable with a self-contained 24-hour clock and up to 8 custom speed and timer functions that allow EcoStar to manage flow throughout the day. Whether used in new construction or aftermarket applications, EcoStar is the perfect choice.</li><br /> <li>Pentair has a calculator that you can use to <a href="http://www.pentairpool.com/pool-owner/resources/calculators/pool-pump-calc/index.html">calculate your energy savings</a> using an energy efficient pool pump.</li><br /></ul></li> <li><i>Pool Covers-</i> A good pool cover will save energy and water. It can keep the water in your pool an average of 10 degrees warmer, which can cut summertime pool heating costs by up to 90 percent. A cover reduces water and chemical evaporation by up to 70 percent, saving nearly a thousand gallons of water per month. A cover also helps keep your pool clean, which means you'll have to run your filter pump less often, saving even more energy.</li><br /> <li><i>Water temperature efficiency-</i> In addition to a pool cover, there are other ways to help keep the cost of heating your pool to a minimum while you still enjoy a comfortable water temperature. Make use of solar energy by locating your pool in the sunniest part of your yard. If possible, screen it from the cooling, prevailing wind with existing structures such as the house or garage, or add a solidly built fence as a windbreak. The water temperature you desire for your swimming pool not only affects the size of the pool's heater, but also your heating costs if use a gas or heat pump pool heater. Heating your pool with solar energy is by far the most energy-efficient method. If you buy a gas or electric heater, check the yellow-and-black Energy Guide label on the appliance. It shows relative energy-efficiency according to tests by the US Federal Trade Commission (FTC). Pool water temperatures typically range from 78&ordm;F to 82&ordm;F. The energy consumption for each degree rise in temperature will cost 10%-30% more in energy costs, depending on your location. In warmer climates, this percentage is higher because of the relatively low cost of heating a pool at 78&ordm;F.</li><br /> <li><i>Timers-</i> Buy automatic timers for both your pool heater and pump. This will allow you to run them in several short cycles during the day, which is more effective than running them once continuously for several hours a day.</li><br /> <li><i>Preventative Maintenance-</i> Maintain efficient daily operations. Turn down the pool heater when the pool is not in use and maintain appropriate water temperatures when in use (78&deg;-80&deg; for active swimming, 82&deg;-84&deg; for recreational use). Raising the water temperature just 1&deg;F can costs an additional 10 - 30%, depending on your location. Keep a thermometer in the pool to help determine the temperature that is best for your pool and mark the "comfort settings" on the thermostat dial to avoid accidental overheating. Backwash the pool filter only as much as necessary to avoid wasting water and energy and be sure to keep drain systems clear to allow the free flow of water. By far, the most energy efficient lights you can get for the pool are LED or solar powered.</li><br /></ul> Energy Efficiency - Not just for pools! It is also possible to make your spa energy efficient. Portable spas are more energy efficient than in-the-ground spas because they are better insulated and usually have covers. If you have a typical portable spa, your heater will heat water 10 degrees in about 8 hours. If you use your spa once a week, lowering the temperature 3 degrees when not in use will save you approximately 5-10% of your spa heating costs; if you use the spa less often, your savings could be even greater. Don't run the jets unless you are using your spa. The mixture of water and air is great for relaxing the muscles, but it cools the water quickly. Spa covers are important. Be sure to leave the cover on until you are ready to use your spa and replace when you're finished. Remember that the heat that escapes is the heat you must pay to replace.
on Mar 17, 2011 • Pool & Spa
2answers
What can i do when my copier says wait warming up but it never gets ready?
Have you checked the manual under Troubleshooting?
The only thought I have is this one;
Is the equipment in the energy saving mode (Automatic energy
saving mode)?
Press the [ENERGY SAVER] or [START] button on the control
panel to clear the mode. (It takes a while for the equipment
to become ready.)
P.43 "3.Energy Saving Mode
Energy smart light stays green but no heat
Depends if you have new or old style energy smart.
Generally this can mean the control board is bad.
Link below has contact information for Craftmaster and Whirlpool and some troubleshoot resources:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Repairs are funneled through the manufacturer who profits by selling non-generic parts not available from local hardware store... with purpose to end DIY repairs, make more money for manufacturer, and build up network of brand-loyal repair service companies who can sign you up with a repair package ... under the banner of saving you $1 a month in energy cost.
Look at label located on side of water heater to find manufacturer and serial number.
If water heater is within 6-9 year warranty period, then parts are covered, but labor is not.
Manufacturer can send parts and/or refer you to local technician.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
• OFF-the feature is off and the power consumption
is normal.
• LOW-power saving level is low and the backlight
brightness level is lower than normal.
• HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
1helpful
2answers
My IBM screen goes dark after being on for several hours. It will return to normal, and then go dark again. Could this be the HDD is getting too hot? Is there a way to increase the fan speed?
Check the energy save settings and see if the monitor is set to shut off after a certain amount of time. Also if the laptop battery gets low it may start to turn off the monitor to save energy. Are you using the computer on a/c power or battery power when this happens? As far as fan controls the settings are usually in the bios but you can sometimes install software that will control the system fan. The BIOS system menu is usually available by pressing delete when the computer boots up(some computers are different button).
When the camera is turned on, it turns off within about 5 seconds. How do you keep the camera on for a longer period of time?
There may be a energy saving function , most of the time in the setup menu check if the energy time can be set
Wireless switch
Make sure you have the latest drivers, router and NB.
Does it connect on reboot with the SSID off?
Does it work on repair?
if so, check your energy settings, some times they power down the wireless to save energy. There are also settings on how it behaves.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
