ERROR CODE oe
Didn't find the service manual but this site is set up great for troubleshooting problems and error codes. This is the link to your specific model.
LG Washing Machine WM2010CWTroubleshooting Repair Help
Testimonial: "I now have a better idea of solution. Thank You"
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the
little basket out that's behind the small door on the lower left front
(where the drain hose is) and look inside. The drain pump intake is
about an inch in on the left. Make sure there's nothing in there like a
paperclip or hair pin. If possible reach in and see if you can turn the
impeller. If it won't move there's something in there if it will turn
then the motor is probably bad.
worked for me
got this from mark1963
SOURCE: LG Tromm Washing Machine Won't Drain code
Hi, //
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
