Inserted the equivalent cartridge PG-840 Error code: E 1 4
Steps to Troubleshoot this Canon Printer Error 2100 Step1: The first and foremost thing you need to do is to determine the size of the paper which is loaded in the printer followed by pressing the OK button on the machine. Step2: A processing method will be displayed on the LCD screen to select Step3: After doing so, reload the papers as per the necessity and use the buttons to select the processing method. As you are done with the entire process, click on the OK button to complete the procedure. Note: To know more about this error and its alternate solutions, you can go through this: https://www.canonprintersupport247.com/blog/fix-canon-printer-error-code-2100/
Dear
You can check which accept the PG-640 ink cart.
http://www.shopbot.com.au/pp-canon-pg-640-price-343368.html
http://www.tipcolor.com/CANON-PG840-compatible-ink-cartridge.html
Check to remove the error code on net.
http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-e04-e05-e14-e15-error-message/
Also you can search on net how to reset for the error code E14 which indicate non-compatible catr. (not genuine fine cart.)
Thanks.
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
SOURCE: printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
SOURCE: the following cartridge cannot been recognized
There's something wrong with the connectors for the control chip on the cartridge - maybe they are dirty or bent out of shape. Or the chip itself is faulty. Or the cartridge isn't genuine (or was refilled) and the chip isn't recognized.
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
SOURCE: canon pixma mp250 showing fault code e05 will not print
Try to stick with original cartridges... Generics only waists time and money
