. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
You need to give more info. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Not sure about this, but my guess would be that you don't have the correct channel set on the DVD recorder. It has to be the channel that you use to receive your signal, NOT the channel that you necessarily want to record. For instance- if you use channel 3 to receive your signal from dish, cable etc but want to record a program on (hypothetically) CBS which is (again hypothetically) channel 24 from your dish or cable provider you would go to "Prog/Check" on the remote, highlight the "New Timer Program" line and press "Enter", and then use the numeric buttons to select channel 3 (the channel you use to receive your signal, NOT 24, the channel you want to record). You will have to program your dish/cable box to provide the channel with the content you want to record, in this case- 24.
Not sure if that was your issue, but hope this helps.
most TV will allow manual entering of numbers on the remote.
if you have the remote try typing "03" thats Zero Three on the remote.
you might have it in video mode like vidoe one or s-video there different mode for a tv. check on the remote for source or TV/VIDEO button, to make sure the TV is in TV mode.
also on the TV itself there should be a menu button some TV have RESET option. look for that
or just goto the WEBSITE of the manufacture of the TV set im sure they have ONLINE manuals too.
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
It all depends on what and how the cable box is connected . Do you have an outside or inside antenna connected? If you have a cable box , why would you want to go to another station on your tv? Does the cable box have an rf output that connects to the tv through he antenna input on the back of the set? If so the tv should stay on a station to recive the stations thru the cable box. Didnt the cable tech explain how to use the system?? If you dont understand how to use the cable you should, for sure call the companey, and see if they can explain how they hooked up your sysytem as theres many many ways to do this. If you have the owners manual what im about to explain is in there too. On the tv remote theres a button called menu, press it once. Use the up and down arrows to scroon down and highlight the setup . press the ok or enter buttonpress the right language,then search for channels. When this is over then exit out of the menu, and try switching channels. If you still dont have any channels you gonna have to find out whats connected to your rf input as channels wont come in if theres not the right source connected. GOOD LUCK
