D
DENNIS SWART Posted on Jan 15, 2015
Any lenses for Braun Paximat 2000 electric?
Looking for lens that fits in just in front of focussing lens.Current lens(plastic)melted due to snapped cooling fan belt.
5 Related Answers
Jim Auburn
  • 412 Answers
  • Posted on Feb 28, 2011
SOURCE: I require a bulb for a Braun Paximat slide
Try checking with www.bulbman.com They have an amazing assortment of lamps for projectors!
Anonymous
  • Posted on Aug 09, 2011
SOURCE: h i I am looking
Hi guys - did you ever find the manual? Specifically, do you know how the remote is supposed to work?
Anonymous
  • 48 Answers
  • Posted on Sep 15, 2011
SOURCE: Can you repair a Braun
Generally, no. But what is the problem?
Anonymous
  • 48 Answers
SOURCE: I also need a Braun
What is the description of the lamp? Braun's current catalog numbers for lamps are 80231 for the 150W 24V and 80232 for the 250W 24V. If you need a different lamp you should bring the old lamp to a camera store and let them look it up from the bulb manufacturers.
Anonymous
  • 48 Answers
SOURCE: I need bulb for braun
You should take the old lamp to a camera store and see if they can find a substitute.
1helpful
My paximat 2000 electric requires a new front convex condenser lens 4mm dia , unable to locate one, any ideas what can be used as a replacement
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
2answers
Want an adaptor for a Nikon D80 to fit canon lenses
Not realistically possible, due to the incompatible lens to focal plane distances. If you found one it would either not allow infinity focussing or would need to incorporate corrective optics which add cost and ruin image quality.
All such adapters mean that the AF won't work, and focussing and image composition must be done with the aperture fully open before manually closing the aperture down to the desired value for metering and shooting. With Nikon G lenses the aperture is fully electronic, so the lens would only be operable at its smallest aperture.
You can get an adapter to allow Nikon to Canon EOS though, but as both cameras have plenty of excellent quality new and used lenses and resale values are high it's a pointless exercise.
Jul 26, 2011 • Cameras
Hi, I bought a CANON FD - 28 mm f 2.8 WIDE ANGLE LENS for my OH's eos 400D, he says it doesnt fit, its too small. Is there an adapter or anything or should I just look for the right one? Many thanks
Canon FD lenses date back to before the mid 1980's. They use a totally different mounting system to the later EOS mount which was a redesign to suit the needs of auto-focussing.
Unfortunately they are chalk and cheese: you cannot realistically fit an FD lens to an EOS camera.
Your fix is to sell the lens and to buy one with an EOS mount.
I also need a Braun Paximat Lamp bulb 58.8394AMX
I need bulb for braun paximat electric projector
2answers
My camera will not focus. I have a 50mm lens and 200mm and neither will focus
Which exact lenses are you trying to use? The N2000 (aka F301) is a manual focus camera so if you're trying to use autofocus lenses you have to focus them manually. Sorry if this seems an insulting suggestion, but you did state "my camera will not focus" and I've learned that on FixYa it's best not to assume any prior level of knowledge with regard to those who post questions.
The next thing to check is whether the viewfinder has an eyecup attached, if so slide it upwards to remove it as sometimes they have a corrective lens fitted if the previous user needed corrective optics. If your vision is fine (with glasses/contact lenses if necessary) then a corrective lens on the viewfinder may make things look blurry.
Other than that, the only other possible cause (other than a pair of broken lenses) is if the focussing screen has become dislodged downwards (or somehow fitted upside-down) then the viewfinder image will be unsharp. Officially the F301/N2000 had a fixed focussing screen but it could be replaced with one of three designed for the higher specified F501 (which does have autofocus), and if not seated correctly you'd get the focussing issue you describe.
You can test if the focussing screen is the problem in one of two ways:-
1. A visual inspection (you may need to get a more experienced photographer to take a look at it);
2. Set the lens to focus at infinity and at the widest possible aperture and take a photograph of a distant object (ignoring the blurred viewfinder). process the film and inspect the photo. If it's sharp then you have a focussing screen problem. If not, then it's a lens problem.
If the problem is a poorly fitted focussing screen then it may just need reseating or to be removed and refitted. It's vital to do this in a dust free environment and to avoid getting fingerprints on the screen. Some screens sit in a hinged frame which then clips into place when pushed up, others push into a pair of clips towards the top rear and then the front is held in place by a spring clip: it's been a long while since I worked on the F501 or F301 so I don't recall which system is used.
Courtesy of Norman Butkus' website, click here for a free Nikon N2000 user manual.
I hope that you've found my answer to be of use, if so please return the favour by rating my answer.
Focussing problem on Sigma 10-20/4-5,6 lense for Pentax
I do have the same lens in Canon version and some time ago had the same problem. The lens has suffer an impact somewhere and was slightly out of alignment. Take it to qualified technician.
May 31, 2017 • Cameras
Top Braun Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
