I have cleaned the filter but I think there is a second one that I can not get out
SOURCE: Samsung washing machine filter
it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
SOURCE: I have a Samsung SW62ASP top load washing machine.
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
SOURCE: Bosch washing machine logixx 8 front loader error
I forbindelse med start af vaskeprogram melder maskinenen F37 fejl? hvad betyder det?
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
