y
yevoo chris Posted on Jan 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I wan to clean an image roller in canon ir 3025N
I want to clean the image roller as one of the remedy to correcting my faded copies in canon ir 3025N
iftikharhmd40
Level 2:
Sergeant:
  • Canon Expert 229 Answers
  • Posted on Jan 19, 2015
iftikharhmd40
Canon Expert
Level 2:
Sergeant:
Answers
229
Questions
6
Helped
128290
Points
636
Clean with dry soft tissue
5 Related Answers
Weigel
  • 4 Answers
  • Posted on Dec 02, 2008
SOURCE: Faded Image coming from Brother 9420cn
You probably have the new roller by now.  But just incase the problem continues, clean the high voltage contact on the right side for the roller and on the drum unit itself.  If it is dirty you'll get light printing.
Anonymous
  • 153 Answers
  • Posted on May 20, 2009
SOURCE: Scan documents on a network folder
yes it is providing it has a send kit installed on the machine, its called windows SMB scanning, and fairly easy to set up should be in your user manual on how to do it.
Canon Tech
Anonymous
  • 16 Answers
  • Posted on Jul 10, 2009
SOURCE: CANON 1600
Try to clean the drum & shake toner & it's nothing to do with transfer roller for sure , it's your drum unit only . Another thing ,was your drum unit exposed to light for more time than normal , in that case try another drum ,try this i think that will solve your problem
jalamb
Aashish Chaudhary
  • 105 Answers
  • Posted on Sep 01, 2009
SOURCE: i have a canon image runner ir 400 machine. i
Delete your printer & install Printer with Ps 1.0
The Driver Is Inbuild In XP Hope This Clear Your Prob.
Anonymous
  • 39 Answers
  • Posted on Dec 17, 2009
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Testimonial: "how to fixing the ir 400 web roller "
2answers
Canon ir-c2220i Faint Print
A feint print is usually caused by a blocked or empty toner.
My iR 3300 is very slow How can I make speed
dear
pl. do setting for image type to text or text/photo. the curling of paper mostly due to the fixing film unit. the pressure roller may softened. replace it or the path have toner clogged clean it with alcohol.
thanks.
Cannon ir 3025n some part not printed when printing or photocopying
Dear
pl. check the drum unit life, clean the drum and its cleaning blade.
Also check the developer roller for uniform toner flowing.
Thanks
What are the steps to solve light copies with canon ir 1024 copier
Did you clean the optik lens,mirrors...?It may also be a transfer roller,try to clean or replace it.
PRESSER ROLLER CUT AFTER 20000 COPIES WHY
This is a low number for that roller.Check the bearings make sure they are not seized. If you have experience a noise then most likely you have bad bearings and the roller is not rotating correctly. The guides may have built up of toner and touching. the seperation guide plate not in correct position or knocked off .under the roller dirt and grime needs to be removed. something is touching the roller causing this and you will get better life from a OEM roller.
Scanning using canon image runner 3025N
Hi Swandi,
Have you installed the scanner utility software before?. If yes, you can use the software or uses other application such as photoshop :)
Have a nice day!
Printer Clinic
4helpful
3answers
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
2answers
Uneven copy quality- Canon Copier
If the toner isnt burned on paper it means that you have to change fixing roller bushings and fixing roller.
Because you have uneven pressure between fixing and press roller
Double imaging (ghost effect) after several normal copies
you can tried to clean the fixing roller or exchange the drum
old marine
old marine
ZJ Limited
ZJ Limited
