Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
L
Larry L Harms Posted on Jan 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak 5300 printing only left half of page after good first page
Replaced printhead replaced both ink cartridges symptoms exist whether printing from computer or printer console powering down printer and waiting for an hour before rebooting reinstates good first page then half page follows
Robert Burlin
Level 2:
New Friend:
  • Expert 128 Answers
  • Posted on Jan 13, 2015
Robert Burlin
Expert
Level 2:
New Friend:
Answers
128
Questions
Helped
27384
Points
246
Try Using An HP Color Inkjet Printer With Only 2 Cartridges,
One Color One Black That Works! If You Don't Have One Buy One New or Used It Does not Matter HP Is The Best!
the one you have Is Defective Anyway And Needs To Be Replaced!
I try to print a card or bank statements and nothing is printing just put in new ink, it only prints the 1st page of a quarter fold card, it should all be on one page and it prints only partial card
IF the Kodak AiO printer is printing partial ther are two main device of the printer that have issue on the scanner [where you put the document for copying] or the printhead of the printer.
Step that you can do
1. Try to print a test page in this way you can check if the printer prints whole page. How to print test page press copy button and photo button on the printer for atleast 10 sec. or until the printer starts printing. Reminder Test page doesn't need a document on the scanner glass. It will print an advertising doc for the printer. Now if the test page is half/partial it is the printhead that has an issue. If it print the whole page it is the scanner that has issue contact kodak for printer repair
2.Clean the printhead twice and reseat the printhead it
How: press menu button then select clean printhead then select basic/deep clean. To reseat printhead open the printer access door; remove the ink cartridges; remove the printhead; close the printer access door then open the printer access door insert the printhead then the ink cartridges.
3. Try to print again [For futher support call Kodak support line at 1 800 421 6699]
3helpful
3answers
My KodakEasy Share 5300 will not print in black.
92b8b47.jpgThe Kodak AiO printers 5000 series and ESP series PRINTHEADs has orange protective cap that need to be remove to fit on the printer carriage. For the ink cartridges 7b91cbc.jpgthere is also a orange protective cap.
Issue that its not printing black and deep clean and removing the printhead and reinstalling the printhead (reseating printhead) is already done and still no black when printing. The printhead should be replace. For futher assistance call 1 800 421 6699 Kodak AiO printer support line
1helpful
It will not print the black ink
Have you clean the printhead and reseating the ink cartridges?
heres the you need to do
-Reseat both ink cartridges
-Calibrate the printhead (Press menu button and look for calibrate printer to do it)
-Clean printhead (press menu then look for clean printhead choose deepclean)
-Press and hold Photo and copy botton at the same time to print your DEMO PAGE!
-If the black is absent it means the nozzles of the printhead is clogged you need to call kodak for printhead replacement Toll Free 1 800 421 6699. GudlucK
1helpful
Kodak 5300 does not print
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
a.Press the Menu button of the printer.
b.Use the down arrow key and go to Clean Printhead.
c.Press OK button then select Deep Clean.
3.Print Demo Page.
Press Photo and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
2answers
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
4helpful
2answers
Kodak 5300 prints with horizontal stripes, changed black cartridge as instructed and no improvement.Did the deep head clean, did calibration , what else can I do?
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
1helpful
My printer 3 in one kodak esp3 the ink is full
upgrade the firmware of ur printer.go to kodak.com/go/printhead support.take out printhead and ink cartridges ,reseat them again.if problem still persists,call kodak @ 1800 421 6699. they will replace ur printhead free of cost
My 5300 printer won't print black ink. I just
Replace the printhead. call kodak at 1.800.421.6699 for a free new one, with FREE ink, too.
Black ink cartridge
You all need a new printhead. If the eyes on the demo sheet (copy and photo at the same time) are coming out all white and they look like zombies the black text isn't working properly. Try cleaning the printhead. If that doesn't work, call kodak, you need a new printhead.
1helpful
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
