If the stop light on your Candy Alise 1400 RPM Washing Dryer is flashing all the time and will not start any program, you may need to reset the machine. To reset the machine, unplug the power cord from the wall outlet and wait for at least 30 seconds. Then plug the power cord back in and press the start button. This should reset the machine and allow you to start a program.
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
unplug the device from the mains for few minutes then check out many a times it clears the fault. A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
What does the error code mean do you have any idea
Is it mentioned in the Hand book.
At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water.
So a tap not turned on
a Kinked hose
An inlet valve solenoid failure-
Three things for you to check
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
