Bowl is full of water, won't progress to spin cycle. PU error code displayed. I have already tested the drain pump motor, and cleaned out the filter, the problem is still happening. Please help, Dan
Hi , the pump is definitely working - I can feel it and hear it running, the bowl is pumped dry. But the spin does not start. With 5 mins to go on Spin Cycle the error PU comes up and a beep sound.
Clothes do not get spun .
Pu is short for pump. You say you checked the motor and filter, but is the motor actually running when it should? If it is, you can hear it. If not, there may be a problem where the pump is not receiving power. Armchair troubleshooting isn't the same as actually being there. Keep hunting and you will find the cause.
Hi
Error code FH appears when No water is detected
entering machine or Pressure switch trip is not detected. If after 30 seconds
the control does not detect water entering machine and then valves will be
turned off and the error code will be displayed. Press PAUSE/CANCEL twice to
clear the display. If there is no water entering the unit then make sure that
the inlet valves are working fine. You may need to check the continuity at the
inlet valves. If the valves are fine then check whether inlet water hoses as
they might be plugged. Also check for inlet water screen at the valve. However,
if the water is entering into the washer then the Drain pump might not be
working. Also inspect the Pressure Switch hose whether it is in good condition
and properly connected to Tub and Pressure switch. Also check hoses for leak
and inspect the flow meter. Hope this helps...
Daniel
