Washing Machines Logo
J
JACKIE Posted on Jan 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The water runs into the machine but then error 11 appears and it stops
Pokinhas
Level 2:
Habit-Forming:
  • Expert 56 Answers
  • Posted on Jan 04, 2015
Pokinhas
Expert
Level 2:
Habit-Forming:
Answers
56
Questions
0
Helped
32422
Points
104
Trouble with the water stop system....
Rdu Appliance Repair
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 48 Answers
Expert
Level 2:
New Friend:
Cheetah:
Answers
48
Questions
0
Helped
12348
Points
196
What's the model number of the washer?
I have error code 15 on my saeco minuto. machine starts initialising the clean start cycle but stops afre a few minutes
https://www.philips.com.ph/c-f/XC000004106/my-philipssaeco-espresso-machine-is-showing-an-error-code
Error Code 11 or 19: Machine needs to adjust to room temperature When error code 11 or 19 appears, allow some time for the machine to adjust from transport/outdoor temperature to room temperature. This can happen more often during the winter period, especially when it is cold and the outdoor temperatures are around zero degrees.
Switch OFF the machine for 30 minutes and switch it on again.
If your espresso machine is showing other error codes or if these solutions do not solve the issue, please contact us for further assistance.
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
The machine starts then stops a few minutes into cycle and the code "F" flashes then "H" flashes? What is the problem? DW 7/31/11
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
2helpful
2answers
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
What does F-11 indicate? Washer stops and door
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
2helpful
3answers
Error code 11 on primus rs16
Error 11 is a water pressure or inlet problem. Check the 1st stage filters in the cold water hoses at the back of the machine.
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
2helpful
How to decalcify?
1. place water and descaler solution into tank
2. remove milk frother from arm
3. place a jug under steam arm
4.hold down the button 2nd from the right next to the menu button for a few seconds.
5.descaling machine open steam knob will appear on the display
6. after descale has finished "fill water tank" will appear.
7. refill tank with clean water no descaler
8.press the button 2nd from the right as in step 4
9. rinsing machine will appear.
10. when finished"close knob"will be displayed
11. refill water tank
12. ventilate will appear on the display
13.press the hot water button and allow to run
14.ventilate will disappear,warming should be displayed.
15. job done !!!
13helpful
3answers
ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Top Washing Machines Experts
john h
