Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Good Day, Your
washing machine is fully automatic?
the
washing cycle is normal?
if yes
do the same maybe it will help you.
for
the fully automatic washing machine mostly have drain pump, please check the
filter of your drain pump, how? remove the cup of your drain pump like a
ordinary cup, screw it clock wise or counter clock wise.
Remove
drain pump filter and clean it, some hair pins, cotton buds or coins or any
small item that coz of clog up.
if
your washing machine dont have drain pump ,but fully automatic check the drain
motor if running or not? how? open the back cover for top loader washing
machine only, select spin cycle and press start to see the drain motor running?
the drain motor is like a small box with small wire to pull the lever of the
drain to remove water inside, if the motor running or pull the lever of the
water pipe but water still inside the washing machine, remove the drain cup or
cover and clean it or check if have coin or cloth inside that coz of clog or
water stuck,
if the
drain pump or drain motor is weak this is will cause and long time draining or
totally not running the drain pump or drain motor and its cause of totally stop
the cycle of washing machine in rinse time or spin time, because all fully
automatic washing machine, after washing cycle the drain pump or drain motor
must be on, to remove water before start the next cycle. rinse or spin cycle.
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle. For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water. ---------- This is how I sorted the machine: - 1. I turned off & unplugged the machine. 2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine. a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry. b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there). 3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :) 4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door. I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so. This may have just saved me a grand$ :) Good luck. cheers Monkeyboy :^)
This displays and error and it can be possible that the inlet flow is low, the inlet filter is clogged or the drain is faulty all of which can reduce the fill/drain timing and so causes an error.. Please remove and clean the filters and check the inlet flow pressure..
see the next steps and use the common sense: God bless you When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. See There's no cold water.
Before the Spin Cycle should start, all water must be drained out of the
machine. If it does not start, it could likely mean the Drain pump may
be clogged. Please follow my below tip on the fix:
I believe your drain pump filter is just clogged. The drain pump is
trying to pump the water out before the Spin cycle, but can't. Usually
this is caused by a foreign object that is obstructing the impeller. See
my tip on how to access, drain & clean the Drain Pump Filter:
