Question about Zeiss Science & Laboratory
Instructions for 4730119901 binocular head - Zeiss Science & Laboratory
Can you change a 3200 swift mono head with a binocular head and where can i find one
Yes, or providing they still make it. The monoc head is just held on with a thumb screw, and you can usually buy just the binocular head itself. You will most likely have to get the part through one of Swift Optical Instruments many distributors or dealers, but if you call Swift directly they will be able to direct you in the right direction: (877) 967-9438
Jan 27, 2011 | Swift M4002D Binocular Microscope
We gave our son a pair of Bushnell Binoculars, and we are having difficulty getting a good image. We have carefully followed the instructions with no luck. The problem is that we are getting a double...
The binoculars need collimation. The two sides are supposed to be parallel, if they are not you see two heads on horses, two footballs, two baseball bats etc. Check the binoculars for any external signs of damage. Are the front housings sitting properly in the body, is one of them not straight? If there is no obvious signs then you will need to take them to someone who can rebuild them for you. Usually the place where you bought them should be able to help you with a repair centre.
Dec 30, 2009 | Bushnell Falcon 13-3450 (10x50) Binocular
How to use distance gauge
Its easier to explain seeing a diagram. Go to Tascos website and download the instruction manual for the Offshore binoculars or Steiner Optic website and download the general binoculars instruction manual. It has all of Steiners models incuding those with a reticle. Most reticles are the same and there is no difference between meters and yards as your calculations are an approximate
Aug 09, 2009 | Fuji CX-C Oceanic Binocular
Ranging reticle in Fujinon FMTRC-SX Binocular
Its easier to explain seeing a diagram. Go to Tascos website and download the instruction manual for the Offshore binoculars or Steiner Optic website and download the general binoculars instruction manual. It has all of Steiners models incuding those with a reticle. Most reticles are the same and there is no difference between meters and yards as your calculations are an approximate.
If your Fujinon is an ex military unit it has what is known as an M22 reticle. It is only slighlty different as it is graduated in mils but the calculations is the same. If it is the M22, google Binocular M22 manual. The military number for this is TM 9-1240-403-12 & P
Mar 22, 2009 | Fujinon Polaris FMTRC-SX (7x50) Binocular
Instructional Manual
this can be obtained by calling bushnell customer service at 1-800-423-3537. additional a manualrm can be found at www.bushnell.com under customer service instruction manuals.
Feb 01, 2009 | Bushnell Instant Replay 8x30 Binocular 5MP...
Rangefinder
Jan 10, 2009 | Optics
Science & Laboratory Logo
123 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
