Has problem trying to get rid of old email address, couldn't delete it, so i reset back to factory setting. reloaded all the downloads, was using it for about an hour, turn it off for the night, tried to use it the next morning, would not turn on. thought battery may be low, plugged it in, waiting an hour, felt both tablet and charger were warm. be two days now trying to get it to turn on, saw reset button in back, tried that, didnt work, help, it;s only two months old
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
