Tv shows code no RGB. What should I start with in trying to fix problem
SOURCE: "No signal" on our new Vizio screen
Try manually using the source button on the TV. Touch the button once and a screen will com up on the TV. Touch the source button again it will scroll down the pop-up on the screen. Wait a few seconds each time you scroll down the pop-up. You should get a signal when it gets to the right setting.
SOURCE: No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
SOURCE: TV will not get off the RGB Screen
I just talked to a tech and fixed mine. unplug tv and hold power button for 1 minute. this drains the compasitors, sometimes they get over charged. if that doesn't work. with tv off hold down input button until tv turns on . it should work. here is tech support # 714-668-0588
SOURCE: Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
