Tried multi power outlets, multi batteries same results no lights on the battery charger and batteries don't get charger
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
SOURCE: Charger not charging
Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
SOURCE: Ryobi Model 1412001, 16vdc, 2A
I had the same problem. No need to repeat it here, but I found this solution worked for me. In case I didn't embed / post it right, copy / paste this into your browser: http://youtu.be/GhRQZEeQzP0 Hope that helps
