Apple iPhone 3G Logo
g
gregory Posted on Dec 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I unlock my iphone or reset it from a sim lock
I cant unlock my iphone when i put in my password it says connet to itune
virgouma
Level 3:
Genius:
  • Apple Master 1,373 Answers
  • Posted on Dec 26, 2014
virgouma
Apple Master
Level 3:
Genius:
Answers
1373
Questions
0
Helped
137303
Points
3737
Hi if you want to unlock your iphone 3g from sim lock to freely use it with any GSM sim ..Then i will refer you to visit sites like TheUnlockSpot.com here they are rendering remote unlocking service to unlock all model iphone from network provider .You first check that whether the service is available for your country and network provider .If yes then pay for it and unlock your iphone 3g then freely use it with any GSM sim ..
2answers
What do i do i forgot my mobile password
Forgetting mobile phone password is a common situation. However, there are several ways to reset the password. Just follow below steps to do that.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Jun 19, 2019 • Cell Phones
Don't know password iPad locked how do I unlock it
In iOS10 how to use easy way to unlock the screen
If you want to use the slide way back to unlock iPhone screen, here's the steps for you to follow.
You should check if your device meets the condition. That is, your iOS device must have Touch ID-enabled feature. Including iPhone 5S, iPad Air 2, iPad Pro, iPad Mini 3 or other later devices.
My daughter gave me this apple iphone six it is at activation lock screen she gave me her id but she cant remember her password what can i do
If the iPhone is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. The following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
How to Unlock Disabled iPhone with without iTunes
Unlocked I forget my passcode
Well, if you forgot the screen lock password for your iPhone, you will have to reset the iPhone to factory settings and then set up a new password. But the factory settings of iPhone will lead to the data loss in your iPhone, as iPhone doesn't save contacts in the SIM card, so you may lose contacts and other data when resetting iPhone. So before doing that, you will need to back up your iPhone data to computer.
iTunes won't be helpful on this issue. When your iPhone is locked, iTunes can't recognize the device. So you will need third party software to help. If you want to backup the contacts, messages and so on, I suggest you use iOS Data Recovery.
http://www.leawo.org/tutorial/how-to-backup-locked-iphone.html
3answers
How do unlock an iphone 4 when have forgotten password
Here you go everything you need to get you out of the mess :)
http://www.everymac.com/systems/apple/iphone/iphone-troubleshooting-repair-faq/iphone-how-to-unlock-open-forgot-code-passcode-password-login.html
I put in the wrong password to many times. Now, it says that the phone is disabled and it need to connet to iTunes. HOw could i connet if the iphone is disabled?
you will need the computer that was originally installed iTune to unlock it. or you will need to contact your plan carrier to reset it for you
1helpful
2answers
No Sim Card Installed Insert a valid Sim with no pin lock
1helpful
2answers
My iphone dont want to accept the simcard
my phone was has problems with itunes asking me for the oreginal sim but how am from africa where can I get this sim from here, pls help!!!
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
