Trying to remove a screw (Whirlpool # 3371152) loose from dishwasher impeller rubber washer. Kenmore Ultra Wash dishwasher model 665.1559579. Trying desperately to determine if the screw is REVERSE THREADED in an effort not to ring off the screw head and have to replace a complete pump assembly.
Does ANYONE have knowledge of what direction this screw is threaded since it is attached directly to the pump motor shaft?
(old question but might help someone in future)
How to take screw of dish washer impeller:
Impeller heats up when the heater at the bottom runs... so maybe impeller melts a bit and sticks on the screw.
Heat up the impeller with a hairdryer for 5 min and try rotating the screw both sides! (this will soften the impeller a little bit so screw can can rotate and come out easily!.
Hold the impeller (somehow); using a nail, some special tool or inserting a screw driver to the side of the impeller.
Unscrew it!
I was trying to take the screw(1SZZED3006A) of the impeller(5911ED3003A) (motor 4681ED1004B) from LG LDS4821ST and had no idea that they put REVERSE THREADED screws in these things, ended up melting the impeller with a torch and then figured that it was a REVERSE THREADED screw!.
Waisted $65 on repair guy who came in and said "you need the sump assembly, recirculation motor, motor assembly" and gave a $368+tax estimate. Didn't check anything just saw a broken part that I already new.
