Health & Beauty Logo
J
John V Kliebert Posted on Dec 21, 2014
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge underneath that shows 2 amber lights on and solid (not flashing). Once you let go of the on button, the three red and four amber LEDs flash, and the 2 amber LEDs on the gauge below disappear. The chair will not operate. Does anyone know what this code means? Thank you
Dave
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Dec 24, 2014
 Dave
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
8650
Points
89
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Previous owner had to have speed adjusted all the way down on my pride mobility jazzy 1103 ultra chair. How do i turn the speed back up
You would need a hand held programmer to adjust the controller settings. The least expensive route short of purchasing a programmer is to bring the power chair into a local dealer to get it programmed. Hope this helps.
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
LED"s flash an error 8
hi,
Joystick code 8 == Controller error
Three red LEDs
Four yellow LEDs
One green LED.
Please confirm this, if you're UK based , i can repair these units...
regards
Rob
www.gewizrepairs.co.uk
Reset button
While replacing the batteries you may have bumped the brake releases. Release both and return them to the operate position. It is also possible to get one or both batteries backwards. This is a 24 volt system so pay close attention to the color codes on the cables. Be careful of shorts.
1helpful
My mother have a pride jazzy serial j-913718 joy stick blink and keeps blinking, I tried what is sugested for the model 1103 but no reults, could someone please help me
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File to read via an Adobe Reader.Hope this was of help,Colin.
1helpful
My brother who died about 2 years ago left a jazzy 1103 ultra mobility chair. Unfortunatley I cannot work out how to start it. Its all charged but can't find ingnition. Can you help please Anne ...
ana at the top of the joystick is the on/off button just push it and the lights sshould come on the battery level lights should all light up and you can set the speed with the two buttons on each side the left to slow down and the right to speed up. When all the speed lights are lit you are at max speed Hope this helps
2answers
Y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
