SOURCE: Similar problem...repairman said the bearings were gone though
bearing will make that noise, but bearings are inexpensive, 650 sounds insane, repairmen dont fix things anymore, he wants to replace the whole motor. call a different repairman
SOURCE: Kenmore washer sounds like a plane taking off while spinning...
yes the rear bearing is gone,,you may have caused the issue by using the wrong soap,,in a front load you must use he soap only,,,the cost to fix 500.00-700.00
http://www.washerwizzards.com
SOURCE: my he2 makes a screaming sound in spin cycle(sounds like a jet taking off)?
The rear bearing in the machine is starting to wear out. This is a major repair that should not be taken on by a non trained technician. If so this will be the most expensive trial and error you will ever have. The part alone for this repair starts around the 421.00 range.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
