I have looked all over the unit for a Wiring Diagram to troubleshoot the defrost timer and its kinda of impossible to determine where the timer power goes to without the Factory wiring Diagram. Also I am looking if I can determine exactly where the defrost thermostat is in the unit before I go and disassemble the unit.
The schematic should be under the kick plate grill. Remove grill and should either be in the grille or behind. Defrost thermostat is located on top of the evaporator behind back panel inside freezer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/keith_6cb11225ab437567
SOURCE: kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
SOURCE: Kenmore refrigerator 5260 not cold
SOURCE: 25357672791 Kenmore S/S will not auto defrost
the TIMER, isthe defrost timer and looks( form the diagram ) to be locaeted behind the toe grille(kickplate), on hte left side. as far as the heater, its located behind the freezer panel and last part in the equation isthe defrost thermostat , which youll find clipped to the top of the alluminum evaporator( alos behind t he rear freezer panel and one of the leadds fron the thermo will lead to the heeater
SOURCE: kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
SOURCE: Where is the defrost timer kenmore side by side 596.52679200
Adaptive Defrost Control will be your timer, Good Luck, Sea Breeze
