Question about As Seen On TV Magic Bullet Food Processor
My Magic Bullet will not start or run. it does not twist in the base. How can I fix that?
    New Friend:
Sounds like the white plastic sliders that turn the motor on and off may be stuck. The sliders engage the 3 tabs on the mixer cup which the push down and turn the motor on. Probably have some leakage from the mixing cup gumming the white sliders up. Unplug the mixer from power and use a cloth or sponge fairly wet with some hot water to try and loosen up the stuff under the sliders. Then spritz the sliders with some WD-40 which will displace the water. Dry it off good with a paper towel, let it dry/drain well upside down on a paper towel before you plug it back in. Good luck.
Posted on Dec 13, 2014
Anonymous
SOURCE:
Magic bullet base is full of particles
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
Sep 18, 2012 | As Seen On TV Magic Bullet Food Processor
Where to buy a magic bullet base gear?
Hi Pamela... Magic bullet base gears can be purchased from amazon (my recommendation). Enter this link Healthy Blend of Power Precision and Value and choose carefully which one fits (by shape, size, price etc). I hope this was helpful. enjoy
Jan 15, 2012 | As Seen On TV Magic Bullet Food Processor
I think my magic bullet over heated and now it won't work. I could smell burning plastic and now when I try to use it, it won't blend. Any suggestions. I hate to buy a new one because I don't need all...
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
Oct 15, 2010 | As Seen On TV Magic Bullet Food Processor
Hey my magic bullet just stopped as i was blending
Jul 10, 2010 | As Seen On TV Magic Bullet Food Processor
My magic bullet has lost the plastic bits that make yhe connection to the base to make it work
Mar 30, 2010 | As Seen On TV Magic Bullet Food Processor
The lid on my magic bullet is jammed, I can't get it off to save my life what do I do
Run it under cold water or put it into the freezer. Sometimes after the bullet is used it gets warm causing the plastic to expand which in turn causes the lid to stick. By cooling it down it should shrink back to its regular size allowing you to unscrew it. You can also wrap some elastic bands around the lid when you try to twist it. This will allow you to get a better grip so your hands don't slip.
Feb 03, 2010 | As Seen On TV Magic Bullet Food Processor
My magic bullet stops rotating
Aug 13, 2009 | As Seen On TV Magic Bullet Food Processor
Food Processors Logo
557 people viewed this question
Top As Seen On TV Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Food Processor Expert? Answer questions, earn points and help others
