Question about Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series
Have a Samsung UN39FH5000 LED TV (a refurb that's out of warranty). Last week the screen went out....still hearing audio, but the screen is completely black. Neither the "welcome" screen, nor any menu
Have a Samsung UN39FH5000 LED TV (a refurb that's out of warranty). Last week the screen went out....still hearing audio, but the screen is completely black. Neither the "welcome" screen, nor any menus are visible. Just a black screen. Opened the back and inspected the components on the three visible PC Boards. All looked OK including the capacitors. Bought three replacement boards anyway on eBay for $36 total and installed them. Nothing changed....TV turns on but the screen remains black. Any ideas before I put the TV out as trash?
  • 5 more comments
  • John DeGrauw Jun 14, 2015
    SO THE TV IS NOW FIXED...finally! It was the LEDs. After a busy Spring work-wise, I got around to ordering replacement LED strips for the TV -- a set of three was just under $32 including shipping. And they were returnable, in case it didn't fix the problem. After I swapped them out and put everything back together...it worked!
    I never did check each LED though....the LEDs look to be hermetically sealed to the base, with no access from the rear of the strip. But I should point out that none of the LEDs looked obviously burnt/discolored.
    Anyway, I took a number of pictures and took notes on disassembly, so I wouldn't forget how to put it all back together. Any questions, just ask. I'll be happy to provide pics/whatever.
    Side view...
  •  Mikey
    Mikey Jun 14, 2015
    Excellent job John.....well done for persevering!
    Thanks Mikey. And thanks for your coaching and advice along the way!
  • Karding Sungkit Jul 21, 2015
    Hi john, thanks for the posting.
    But can you give me the site where you bought the LED's? And can you guide me how to get through those LED's as well? Thanks a lot
  • Christian Santos
    Christian Santos Jan 09, 2016
    hi i have the same tv and problem but i cannot find those LED strip???
  • Tim De Lord Feb 16, 2018
    ShopJimmy.Com stocks the LED Strips! They come in a pack of (3)
    Master:
  • Samsung Master
  • 450 Answers
This is the common problem for this model, that the TV powered up, has sound, but no display.
1. Open the back cover & turn the TV on, if the back lights is not on, please check the voltage on CNL802 on power supply board, it should be 140V DC (Between the blue & black wire),
A. if the voltage is there, it indicates the LED strip inside the panel is defective, you have to replace the LED assy to fix it.
B. If the voltage is not there or low, then measure the voltage on Pin 1 & 5 on CNM805, the voltage should be 12-13V DC, if the voltage is right, the power supply is bad, replace it.
C. If one of the voltage is low, or not presents, replace the main board.
2. If the back lights is on, but no display,
A. Please check the fuse FP1 on the T-CON board, if it is open, replace the T-CON board.
B. If the the fuse is OK, please replace the main board.
C. We do have some special instances that the main board & T-CON board is OK, but the LCD panel buffer board has problem , if this is the circumstance, your TV is not worth to repair.
If you have any more question, fell free call me at (541)683-8887.
I hope that this would help you.
Posted on Feb 03, 2016
    New Friend:
Hey John,
Did you end up repairing your Samsung ? I am having issues. replaced 3 boards, and my result is blue flashing, ans flashing display. No sound, no video.
Posted on Oct 14, 2015
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Im having the same exact problem on mine also .anything end up working?
Posted on Jun 09, 2015
  •  Mikey
    Mikey Jun 09, 2015
    If there is a faint picture.....shine a light at the screen when on and you should see an outline, this is the screen inverter that is faulty!
  • Heather Jun 09, 2015
    No faint picture,nothing at all
Hi, My name is Wayne and I own Affordable Mobile TV Repair in Va Beach Va. If you have any soldering skills, you can repair the LED strips. The easiest way to do this is to take your multimeter and check the resistance across each led. In one direction the led will light up slightly. In the other direction, the LED will not light. That will show that the LED is working. LEDs either short or open. If they short, they need to be removed. If they are open you can just solder leeds over the open LED and attach additional LEDs as necessary. For additional information, please go to AffordableMobileTVRepair.com and submit a service request for FREE technical information. thanks
Posted on Apr 21, 2015
    New Friend:
Hey, John, did you ever find a solution to this problem with the Samsung LC TV. I have exactly the same problem and all three boards did not fix the problem. I have the whole TV apart now down to the led strips and am clueless. Wondering if you found the problem.
Posted on Mar 25, 2015
Testimonial: "In fact, no. At this point it's an academic exercise for me! I have the TV apart as well, down to the LED strips. Sourced them on eBay but I'm finding that -- unlike the boards -- the LED strips are not returnable. Will be testing the LED strips at a friend's house. He has a variable power supply and we'll see if the LED strips are good. But I can say that none look burnt. At the time my friend was over and he checked the cold-side voltages (on the old power board that's now reinstalled) going to each LED strip and they all seem to be within spec. Will report back on my progress"
  • 3 more comments
  • Rj Mueller
    Rj Mueller Mar 25, 2015
    This has become sort of a challenge to me now. It started out as sort of a simple problem because one of the three boards had to be bad, right? Nope, unless one of the boards I bought on Ebay are the problem which is highly likely. Do you know what voltage to appy to the strips. I had the same idea to test the strips by just applying a voltage but don't know what the voltage is. I tried finding a schematic or diagram of this TV but nothing out there.
  • John DeGrauw Mar 25, 2015
    I Unfortunately I don't know the voltage. My friend is an appliance/tech repair guy and knew from looking at info the power supply circuit board what the output voltages were supposed to be. I'm due to go there this week (or weekend) with the TV to test it. Btw, I had that exact same logic about the board swapping...highly unlikely that a board from a unit with a cracked LCD would be faulty.
    Fortunately all three boards were returnable without a restocking fee.
  • Rj Mueller
    Thanks for the info. I am going to fire up the TV again and see if I can get a voltage reading and then run the lights to see if they light up. It is a backlight problem so it must get power from the power supply board but I changed that. Strange problem. let me know if you get some other info on this. I am dead-ended. I even found a TV repair place to take it to but the guy declined as he said he would have done just what I did.
    Hey RJ. Not sure if you'll get the notice of my latest post, so I figure I'd comment directly to your thread. The TV is fixed. The problem was with the LED strips, btw.
  • Samsung Master
  • 5,746 Answers
Can you see a faint picture when looking up close to the screen? If so this could be the screen inverter that lights up the screen that has gone!
Posted on Dec 14, 2014
Testimonial: "Thanks for the reply, Mikey, but I don't see a faint image. I'm in the process of returning the three boards I bought on eBay. As a last resort I ordered the cable set for this TV on eBay ($12 including shipping). I'll swap out the cables one by one to see if anything changes. Who knows.....the solution might be that simple!! Will report back after I get them and test."
  • 9 more comments
  •  Mikey
    Mikey Dec 14, 2014
    Your right it's worth a try..... But normally if the cables are faulty you would get a white screen! This appears to be showing symptoms of the backlight....... Can you turn the TV on and shine a torch at the screen to see if there is a faint picture visible?
  • John DeGrauw Dec 21, 2014
    Hey Mikey. Had time today to do a little more testing on this. I got the cables and replaced them -- still the same problem with the black screen. Also, I did as you said and shines the torch at the screen and I DO see a faint image. But I replaced all three boards...you would think that would have fixed the problem, right? In any case, which of the three boards show in the picture would control the backlight? Although it's unlikely, maybe the "new" board that controls the backlight was bad too?
  •  Mikey
    Mikey Dec 21, 2014
    Hi John, I am familiar with screen inverters boards on laptops and these are separate! It could be the inverter board is built in to one of the boards you replaced and could be faulty but we will assume for now that the boards are ok! This could point to the LED bulbs or the board is separate!
  •  Mikey
    Mikey Dec 21, 2014
    On laptops the inverter board is located at the bottom of the screen and visible from the front! Can you see where the LED lights are and trace it back?
    First, thank you for your amazingly prompt responses. As I was tinkering earlier I took the whole TV apart, realizing that I had nothing to lose. I traced the cable from the power board to three rows of LEDs. I would think that the LEDs are OK....unless if one goes bad they ALL go out, like a cheap string of Xmas lights with a blown bulb?? The small PC board (the T-Con board) is shown at the bottom of the TV, feeding the PC boards along the bottom edge. Here's a link showing a labelled picture:http://johndegrauw.com/samsung-UN39FH500...
  •  Mikey
    Mikey Dec 22, 2014
    Ok! Have you a test meter? I would try and trace back through the circuit board from the plug at the top going to the bank of LEDs and test the resistors along the way! Since there does not seem to be a separate inverter board, it could just be a bad resistor if you are lucky!
  •  Mikey
    Mikey Dec 22, 2014
    We could rule out the LEDs being bad as you correctly stated if 1 led was bad then they will all go out but since you have 3 banks only 1 bank would go out, unl
  •  Mikey
    Mikey Dec 22, 2014
  • John DeGrauw Dec 22, 2014
    I do have a meter and I'll start checking the resitors for continuity and proper resitance. I have a noobie question, however....can restistors be tested on the board, or do they need to be removed from the PCB to test? Fyi, prior to buying the replacement power board I desoldered to two large blue caps and tested those as OK out of the circuit, as per some YouTube video I watched.
    "THE two large caps" not "to" btw
  •  Mikey
    Mikey Dec 22, 2014
    Yes resistors can be tested without removal! Make sure no power and capacitors are discharged, I would remove the top right board and follow the track from the plug for the LED bulbs!
6ya staff
SOURCE:
Need a copy of schematic for Samsung TV UN39FH5000f
http://www.servicemanuals.net/SAMSUNG/UN39FH5000-NO-SCHEMES/1581155/detail.aspx
Dec 06, 2016 | Samsung 5000 Series UN39FH5000 39" LED TV...
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
The screen has gone out, I hear audio and can see the screen on with the flashlight test. I look through the vents and the backlight is not on. What do I replace? Which board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 13, 2016 | Samsung UN39FH5000 39IN 1080P 60HZ LED TV...
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung LED TV (UN39FH5000FXZA) has audio, but does not have backlight. I replaced the power supply/ LED board with no success, could this be caused by the main board or the t-con board?
Hi Matt,
The fault lies with the backlight LEDs. It is common with these sets. If you open the panel and replace the failed LEDs, or replace the panei.
Good luck.
Dec 05, 2015 | Samsung 5000 Series UN39FH5000 39" LED TV...
Led tv no picture
Sounds like fluorescent tube has gone, but you say this is LED? Newer tvs are LED. What you have, may be LCD, in which fluorescent tubes were used. You have no recourse.
Feb 12, 2014 | Televison & Video
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Feb 24, 2010 | Samsung 50 in. Plasma TV
LED screen not working
Could be the tube[backlight] has blown. Can you see any image on the screen if you angle it around to the light? Check the Manufacturers Web site- tech support If it is a young camera they may offer a refurb on in exchange if you are out of warranty
May 12, 2007 | Canon PowerShot A75 Digital Camera
Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
5,746 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
