Conair Deluxe Rechargeable Beard & Mustache Trimmer Logo
r
rajkumar gandhi Posted on Dec 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i conair deluxe beard rechargeable beard & mustache trimmer
How to reassemble my conair deluxe beard and mustache trimmer spring
Reno Smidt
Level 2:
Habit-Forming:
New Friend:
  • Expert 113 Answers
  • Posted on Dec 12, 2019
Reno Smidt
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
113
Questions
0
Helped
9798
Points
431
I suggest you to buy new device
jfbgm1
Level 3:
Master:
  • Master 706 Answers
  • Posted on Dec 07, 2014
jfbgm1
Master
Level 3:
Master:
Answers
706
Questions
0
Helped
166077
Points
1075
It sounds like it was taken apart by someone else???. Conair has a web-site which should give you diagram for putting it back together. Hopefully, all parts are there and undamaged.
3 Related Answers
Anonymous
  • 12 Answers
  • Posted on Aug 11, 2009
SOURCE: The blades are misaligned on my Conair beard trimmer
Take them off by unscrewing them and realign
Anonymous
  • Posted on Jan 15, 2010
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Anonymous
  • 15935 Answers
  • Posted on Sep 05, 2010
SOURCE: changing trimmer heads on Conair Beard Trimmer - Model GMT188
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Are there batteries in the Jheri Redding cordless hair trimmer model JRK0691?
Question edited for clarity
Question moved from Cars and Trucks Category.
This is a 50 year old trimmer brought out in 1971 ish. There will be a nickel cadmium battery in it which will be well past its best. You can replace it if you can find a way to get inside it. The brand is owned by Conair, so you can ask if they will change the battery for you? I am sure they will say it is obsolete. If you can get inside it, you can get all replacement batteries from www.batterybuyer.com
Also, it is entirely possible that the motor has failed, so before replacing the battery, you need to test it with some type of external battery source.
https://www.google.com/search?q=jherri+redding+JRK0691+replace+battery
27helpful
4answers
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
1helpful
All I need is a spring for my conair trimmer and information on how to obtain it?
mcdevito75 here, Online you should be able to contact Conair.com for parts.
My age is 22. my mustache is not growing properly so give me any soluton??????????? plzzzzzz wtg
its a heridetary problem in most cases. there is a simple solution from which most people have been benifited. take a ginger and just chip the upper portion by blade . rub twice daily and you will get the result in 3 months time.
3helpful
4helpful
I purchased the conair trimmer model GMT175W I purchased it second hand and don't have the manual the small blade was attached and I can't figure out how to attach the larger cutting head. Can you help me?
Just twist and pull backward on the tip where the seam is. It does kind of feel like you're going to break it, but it won't--it is made to snap off like this.
3helpful
Conair beard trimmer: took screw out and can't
Need a manual
im having problems changing the trim head
1helpful
Changing trimmer heads on Conair Beard Trimmer - Model GMT188
Top Conair Health & Beauty Experts
ZJ Limited
ZJ Limited
shaveroutlet.com
shaveroutlet.com
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
