Question about Zanussi Washing Machines
Fit door seal on a zanussi washer
Cannot fit spring into the door seal
    President:
  • 1,462 Answers
This is not easy and there is a real knack to it. You will find it easier to have a second person helping. One holds the spring in position at the top and the other at the bottom and roll the spring over your hands into the slot
diug
Posted on Aug 16, 2015
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 135 Answers
SOURCE: I am trying to fit
Its a tricky one but the easiest way is tolubricate the inside of the flap with wash up liquid then starting at bottom feed it on bit by bit following round with other hand to stop it slipping off. Once on its easy to rotate into correct position.
You will need an extra pair of hands to help with the spring.
Hope this helps & thanks for using Fixya.
Posted on Jan 10, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
apart4u
apart4u
  • 213 Answers
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
How do u fit door seal on a zanussi fjdr 1666w
Removal of the Seal.
Remove plastic clamp holding seal to cabinet and peel off the cabinet. Push downwards on the seal close to the tub and the seal will come off - its just held by a spring around the outside.
To fit the new Seal.
Lubricate the slot which fits over the tub with washing-up fluid.
Starting at the top, press the seal, so the flange of the tub enters the slot on the seal.
Work your way round the using thumbs to force the slot on the tub flange.
When the slot is on the flange all way round, fit the spring which holds it on.
The spring goes into a slot on the outside of the seal.
This is difficult, you may need another pair of hands.
Fit the outside of the seal to the cabinet and fit the plastic clamping ring.
Test for leaks.
Use Rinse to test for leaks, since the water level is higher.
Sep 10, 2017 | Zanussi Washing Machines
Cannot fit door seal l have tried but the spring will not sit inside
Judith, these things are a bi**ch to fit. You need 3 hands and patience by the bucket load. Try a good DIY neighbour or lastly an appliance engineer. Its all about experience and having the knack to fit one. Sorry.
Dec 04, 2014 | Zanussi ZWF1430W Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fitting of door seal on zanussi electrolux washing machine model aquacycle 1200 xc6 how do you get the the the door seal fitted finding it impossible almost
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Mar 12, 2009 | Zanussi FLA1201W Front Load Washer
Trying to fit new door seal with spring keeper to washing machine
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
The door seal needs changing
not too bad a job. remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery. to fit new seal lubricate the slot which fits over the tub with washing-up fluid - essential! starting at the top, press the seal so the flange of the tub enters the slot on the seal. work your way round the using thumbs to force the slot on the tub flange - easy when you have done it once but hard the first time. when slot is on the flange all way round, fit the spring which holds it on.the spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands. fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring. test for leaks before using in earnest. use rinse to test as the water level is higher
Mar 27, 2007 | Zanussi FLA1201W Front Load Washer
How to fit a door seal on a Zanussi FJ 1295
this is a faily easy task essential to lubricate the seal with washing-up fluid in the slot which goes on the tub. enter the lip of the tub into the slot on the seal and work round in both directions forcing seal on with thumbs. the spring goes into a groove so as to keep it in position on the tub. then similiarly, put the seal on the cabinet and follow up with the plastic ring
Feb 24, 2007 | Zanussi FS1255S Front Load Washer
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
